engine will not turn over
195,000 MILES • 3.4L • 6 CYL • AUTOMATIC
DANE DESPAW SR.
  • 75 POSTS
Sometimes when I turn the key, it starts right up. Sometimes I turn the key and get nothing at all. If I leave the key on and get under it and jump across the starter with a screwdriver, it will spin, but won't kick in and engage with the flywheel. I replaced the starter, and have the same results. Is there a way to test the relay? Or should I be looking somewhere else?
Jun 20, 2020 at 5:09 AM
Good afternoon,
I attached a wiring diagram for you to view.
Do you have a test light or voltmeter to do checks on the starting system?
Jun 20, 2020 at 5:24 AM
DANE DESPAW SR.
  • 75 POSTS
Yes I do. I have also been advised that it could have something to do with security system? When I turn the key on, the icon for that stays lit. I don’t know if it’s supposed to though.
Jun 20, 2020 at 5:53 AM
Okay, it should go out after about 10 seconds. Does it do that?
I attached a guide to reset for you to try as well.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Jun 20, 2020 at 6:13 AM
DANE DESPAW SR.
  • 75 POSTS
The security stays on as long as the key is on. I will try the reset steps you sent me.
Jun 20, 2020 at 6:29 AM
Okay, sounds good.
Keep us updated with the results.
Jun 20, 2020 at 6:38 AM
DANE DESPAW SR.
  • 75 POSTS
I tried all the steps you forwarded to me and they didn’t work. I left the battery disconnected overnight, still nothing. I turned the key in this morning and after just 2 or 3 minutes, it started doing this (see video). As of now, the security light is not on, but it still won’t turn over.
Jun 21, 2020 at 12:12 AM
Okay, I could not hear a thing. What was being done during that video?
Jun 21, 2020 at 12:16 AM
DANE DESPAW SR.
  • 75 POSTS
I was just sitting with the key in the on position. The security light and a couple other lights started flashing rapidly and then the security light turned off. It was staying on and solid (not flashing) before this occurred.
Jun 21, 2020 at 12:24 AM
Okay, does the engine crank over now?
Jun 21, 2020 at 1:29 AM
DANE DESPAW SR.
  • 75 POSTS
Okay. The security light has gone out. I’m not getting power to the solenoid. Battery is fully charged. Checked fuses, all good. Swapped relays around. Still nothing.
Jun 21, 2020 at 1:49 AM
Okay, you need to go to the relay.
With the key on, remove the relay and test for power at one of the pins. You should have 1 pin with power.
Then have someone hold the key to the start position and there should be power to another pin.
I posted the wire diagram in my first response.
Jun 21, 2020 at 1:54 AM
DANE DESPAW SR.
  • 75 POSTS
I am getting power to two pins with the key on and when turned to start position.
Jun 21, 2020 at 2:02 AM
Okay, with the key on, only one should have power. The second power should only be there when the key is in the start position.
Okay, install the relay again. Have someone turn the key to start and see if the relay clicks.
Jun 21, 2020 at 2:09 AM
DANE DESPAW SR.
  • 75 POSTS
Yes it does click.
Jun 21, 2020 at 2:14 AM
Okay, the control side is working.
Go to the starter itself and the little wire on the solenoid. The little purple wire should have power in the start position.
If it does, you need a starter motor.
If it does not, then you have a wiring issue between the fuse block and the starter solenoid.
Jun 21, 2020 at 2:18 AM
DANE DESPAW SR.
  • 75 POSTS
The wire to the solenoid doesn’t have power. I also want to note the start fuse next to the relay doesn’t have power to it either.
Jun 21, 2020 at 2:24 AM
You stated you had 2 powers at the relay, one in the start position. If you did have that power, then it passes through that fuse. That fuse is only hot in the start position.
If the relay clicked, power has to go through that fuse.
Jun 21, 2020 at 2:27 AM
DANE DESPAW SR.
  • 75 POSTS
Okay. I didn’t know that, so I wanted to point it out.
Jun 21, 2020 at 2:28 AM
I would have gone there if you had to power to the relay in start position.
Jun 21, 2020 at 2:35 AM
DANE DESPAW SR.
  • 75 POSTS
Just re reading some of your responses. Relay has two pins with power whether the key is just on and in start position both.
Jun 21, 2020 at 2:40 AM
DANE DESPAW SR.
  • 75 POSTS
I’m leaning towards the problem being in the fuse block itself. Would you think the same?
Jun 21, 2020 at 2:41 AM
If the relay energizes when you turn to start, the control side is working.
Did you verify no power to the purple wire at the starter solenoid?
Jun 21, 2020 at 2:51 AM
DANE DESPAW SR.
  • 75 POSTS
Relay has two pins energized in start and on position. No other pins energize when in start position.
Jun 21, 2020 at 2:55 AM
There should not be any power on the other 2.
We are beyond that now and working on the purple wire to the solenoid.
Again, if you have no power to the solenoid, and the relay is clicking, you have an open in the purple wire from the relay to the solenoid.
Jun 21, 2020 at 3:03 AM
DANE DESPAW SR.
  • 75 POSTS
10-4. Will let you know what I figure out.
Jun 22, 2020 at 2:02 AM
Sounds good.
Keep me updated.
Jun 22, 2020 at 2:13 AM
DANE DESPAW SR.
  • 75 POSTS
Yesterday after I got home from work, just for grins, I tried starting the car. All the warning lights in the dash came on as expected, including the security light. It went back out as it should. When I tried turning the key to start, the security light began flashing rapidly, just like it did in the video I sent you a couple days ago. I’m thinking the issue may still be with the security system. Thoughts?
Jun 23, 2020 at 3:23 AM
Yes, I agree.
Can you check for any codes set and did you try the reset for the system?
Jun 23, 2020 at 3:29 AM
DANE DESPAW SR.
  • 75 POSTS
Code reader shows no codes. I erased codes after fixing an overheating problem. I did go through the steps you sent me for resetting the security system. But I will give them another try and let you know the results.
Jun 23, 2020 at 4:22 AM
Okay, keep us updated.
Jun 23, 2020 at 4:26 AM
DANE DESPAW SR.
  • 75 POSTS
So, it ended up being the ignition switch... I appreciate all the guidance I’ve received from y’all.
Jun 28, 2020 at 4:32 AM
Good deal.
Glad it is fixed.
Always glad to help.
Jun 28, 2020 at 8:52 AM
DANE DESPAW SR.
  • 75 POSTS
Hello again, I’m back to having an engine that won’t turn over. Security light stays on solid when key is in on position. No power to relay or starter fuse. Reset steps you sent me a while back have no effect. Last time, I replaced the ignition starter switch and it fixed the problem. This time, as of now, I’ve replaced the key cylinder and put another ignition starter switch in. Starter fuse isn’t blown. Relay has continuity across 2 points. But no power getting to them at all when key is turned on.
Aug 24, 2020 at 6:45 AM
Okay, can you check for codes again and see if anything is set?
Aug 24, 2020 at 7:09 AM
DANE DESPAW SR.
  • 75 POSTS
It was registering an engine misfire code. But I replaced the plugs and plug wires and that stopped that problem. Now it’s showing engine speed input circuit no signal (P0727) and crankshaft position sensor (P0335).
Aug 24, 2020 at 7:23 AM
Okay, the 727 code has only 1 result. You need a ECM. It has failed. You need to replace that first before looking at the 335. The 727 could take care of that code as well.
It also take care of all you other issues.
Aug 24, 2020 at 7:31 AM
DANE DESPAW SR.
  • 75 POSTS
Ouch!! Okay, how difficult is it to program to the vehicle?
Aug 24, 2020 at 7:41 AM
You need an advanced scan tool with access to GM technical web site to download the software.
Otherwise, you need a shop to do this for you.
Aug 24, 2020 at 8:08 AM
DANE DESPAW SR.
  • 75 POSTS
Alright. I figured as much. I appreciate your help.
Aug 24, 2020 at 10:21 AM
You are welcome.
Aug 24, 2020 at 7:22 PM
