Engine will not restart after turning it off
50,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
CHARLES DANBERRY
After driving the truck for short distance then turning it off, it will not restart. It fires and turns over but it acts like it is not getting fuel or something. It started after sitting overnight or several nights. The garage checked the fuel pump, changed a fuse, and did diagnostics and they could not get it to quit when they had it.
Believing it was okay we drove it again and the same thing happened again leaving us stranded.
Feb 4, 2018 at 11:57 AM
  • 55,748 POSTS
When the engine is not running we need to check for spark because it sounds like a crankshaft angle sensor is going out.
Check out this guide near the bottom to show you how to check for spark.
Cheers, Ken
Aug 12, 2020 at 10:59 AM
