Engine will not restart when hot
150,000 MILES • 3.7L • 6 CYL • 2WD • AUTOMATIC
NEAL J
Cannot restart after the engine has been driven for a period of time and is hot. Running good not showing any trouble alarm so haven't check for codes. Will crank over but no fire. Once cooled down for approx. 20+ minutes may start as normal. Not overheating.
Dec 16, 2021 at 9:14 PM
Good morning,
When it will not start, you need to test for spark and fuel pressure to see which system has failed.
Once you find which system is not working, then we can narrow down the failure. Let me know the results of the checks.
Dec 16, 2021 at 11:20 PM
NEAL J
Thanks Roy. I will respond as soon as I can test it when it occurs again.
Dec 16, 2021 at 11:36 PM
Sounds good. I will be here to help.
