Well you picked a truck engine and the truck engine was throttle body injection and the car is a 305 HO with tuned port injection the cams and compression are not the same. The cams are different and the heads are different. The TBI truck engine is cammed.234 and.257 with 1.84 and 1.50 valves and the 9.3:1 compression. The TPI car engine is cammed.269 and.276 with 1.94 and 1.60 valve and 9.5:1 compression. The Hp is different and torque. It will run rich and not have the power and such. As for the sensors you do have everything hooked up and pluged in? Double check everything and let me know what you find, do you have digital multi meter? We will need to test some sensors and maybe some wiring.
Tuesday, April 21st, 2020 AT 11:41 AM
(Merged)
