Engine stalled while driving and will not start?
212,000 MILES • 2.5L • 4 CYL
ISAAC JOHNSON
No check engine light, but the service light came on I replaced the cam and crank sensor and new fuel pump with no results. vehicle will not start.
Jul 16, 2022 at 5:18 AM
  • 110,244 POSTS
Have you confirmed the fuel pressure is within spec and you are getting spark to the plugs?
Do me a favor. See if it starts for a couple of seconds if you use starting fluid. If it does and then stalls, it's fuel related. If there is no change, chances are it is ignition related. At that point, you would need to check for spark at the plugs.
Here is a link that explains how it's done:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Let me know what you find. Note: If possible, record it cranking and upload it for me to hear.
joe
Jul 16, 2022 at 4:10 PM
