Engine runs hot when decelerating
222,500 MILES • 5.7L • V8 • 2WD • AUTOMATIC
CORNICUS
Car was just purchased for $800.00. Everything looks and sounds clean. Rides amazing no knocking, cracking, creaking, squeaking, or abnormal sounds or sensations. When driven around city everything behaves per usual. When driven on highway when decelerating the engine runs very hot. Comes right back down after a few seconds of either staying still or accelerating. I'm trying to use this as temporary means of transportation for a few months. I was wondering if by my not very thorough explanation of the problem I'm having you could maybe point me in the direction of remedy. I can answer questions if there's follow-up needed. Thank you so much. This is a wonderful act of generosity from all of you guys for giving free advise.
Dec 10, 2019 at 6:51 AM
  • 110,248 POSTS
The problem only happens when you slow down from highway speeds? Interestingly, one would thing the opposite would happen. Tell me. Have you checked engine coolant? Is it clean and full?
https://www.2carpros.com/articles/engine-cooling-system
Let me know. Also, let me know if it happens all the time.
Dec 11, 2019 at 11:44 AM
CORNICUS
It happens all the time. The coolant is at full and appears to be clean. Seems to happen all the time now. It goes up until it hits 260 then right back down after a few seconds to around 180-190.
Dec 19, 2019 at 5:43 AM
CORNICUS
It also only has one huge belt driven fan behind the radiator that is working from what I can tell.
Dec 19, 2019 at 5:44 AM
  • 110,248 POSTS
If it is doing it all the time, and gets that high and then drops, it sounds like you have a thermostat sticking or maybe even the temp sensor is bad. I hate to ask this, but when it shows 260°F on the gauge, does it seem as though the engine is actually that hot? For example, is there any coolant sounds, steam, or coolant coming out of the system? I would hate to say replace the thermostat and find that isn't the issue and that the engine really isn't that hot.
The strange thing about this is that it happens at highway speeds and not in town. That is the opposite of the normal overheating issues.
If you want, here are directions on replacing a thermostat. You can check the old thermostat by dropping it into boiling water to see if it opens. However, once it's out, I would just replace it, but that would be your decision.
Since it drops as fast as you described, I suspect it is the thermostat sticking, but a faulty temp sensor should also be considered. I do have one other thought. Is the cooling system pressurizing when it is at operating temp? In other words, do the radiator hoses get hard from pressure?
Dec 19, 2019 at 11:39 AM
