Engine revs fine in park, but not in neutral, lunges, loses power
B_WILL
  • 2008 NISSAN ALTIMA
  • 2.5L
  • 4 CYL
  • 200,000 MILES
1. My car has started to completely lose power when you accelerate too quickly. Engine won't rev, no acceleration. I can turn the car off, let it set for a few seconds, and turn it back on and it's fine. 2. Sometimes when you accelerate there is very little power and then it lunges, but it won't hold a steady speed. Turn car off for a few seconds, turn it back on, and no issue. 3. I can rev the engine when it is in park and it is a smooth acceleration form 1000 rpm's up to 3500+ rpm's, but if I put the car in neutral and start accelerating, the tachometer starts to bounce around 1,500-2,000 and never stabilizes. It doesn't matter how far I have depressed the accelerator.
Tuesday, June 25th, 2019 AT 2:33 PM
  • 109,771 POSTS
Welcome to 2CarPros.
Is the check engine light staying on when the engine is running? If it is, then you need to scan the computer for diagnostic trouble codes. That will point us in the right direction,.
Here is a quick video showing how it's done:
https://youtu.be/YV3TRZwer8k
I realize most people don't own a scanner, but often times a parts store will do it for free or lend/rent you a scanner. If the light stays on, that is step one
Now, is there anything that you can think of that may induce this to happen? For example, does it do it only once the engine warms up?
Wednesday, June 26th, 2019 AT 7:21 PM
B_WILL
Thanks Joe.
I did at one point. It had a code for one on the 02 senors. I think it was the downstream, but I can't remember for sure. I'm off tomorrow, so I can get it checked again.
Brian
Thursday, June 27th, 2019 AT 4:22 AM
  • 109,771 POSTS
Welcome back, Brian. Do that and let me know. A bad 02 sensor can play havoc with the air / fuel mixture to the engine.
Thursday, June 27th, 2019 AT 3:25 PM
