Engine rebuild, torques specs?
14,800 MILES • 5.0L • V8 • 2WD • MANUAL
FOXBODY.302K
  • 21 POSTS
Hello, my name is Jr. I am currently rebuilding my stock 302 engine from my Foxbody, I'm going with cam B303- and Forged pistons, I watched a couple videos on YouTube on how Ryan builds a 347 stroker. I was wondering if I could go with the same torque specs for my stock 302 that he used for his 347?
Aug 24, 2022 at 6:25 AM
  • 55,561 POSTS
Sure, here are the 302 Ford engine torque specs you requested:
Specific Applications Alternator Bracket to Cylinder Block Bolt 16-24 Nm
Alternator Adjustment Arm to Cylinder Block Bolt 16-24 Nm
Alternator Adjustment Arm to Alternator Bolt 32-54 Nm
Carburetor Attaching Nut 16-24 Nm
Camshaft Sprocket Gear to Camshaft Bolt 54-61 Nm
Camshaft Thrust Plate to Cylinder Block Bolt 12-16 Nm
Carburetor Mounting Stud 20 Max. Nm
Connecting Rod - Nut: 5.OL (302 CID) 26-32 Nm
Connecting Rod - Nut: 5.8L (351 CID) 26-32 Nm
Cylinder Front Cover Bolt 16-24 Nm
Cylinder Head Bolt: 5.OL (302 CID) (1) -
(1) Torque in 2 steps: First step 75-88 Nm (55-65 ft-lb) Second step 88-97 Nm (65-72 ft-lb)
Cylinder Head Bolt: 5.8L (351 CID) (2) -
(2) Torque in 3 steps: First step 115 Nm (85 ft-lb) Second step 129 Nm (95 ft-lb) Third step 142-151 Nm (105-112 ft-lb)
Damper to Crankshaft Bolt 95-122 Nm
Distributor Hold Down Bolt 24-35 Nm
EGR Valve to Intake Manifold Spacer 16-24 Nm
Exhaust Manifold to Cylinder Head Bolt 24-32 Nm
Fan to Water Pump Hub - Bolt 16-24 Nm
Flywheel to Crankshaft Bolt 102-115 Nm
Fuel Pump to Cylinder Block - Front Cover Bolt 26-37 Nm
cf301021-014_svg
Intake Manifold to Cylinder Head Bolt (3) 5.OL/5.8L (302 CID/351 CID) 15/31-34 Nm
(3) After assembly, retorque with engine hot.
Main Bearing Cap - Bolt: 5.OL (302 CID) 81-95 Nm
Main Bearing Cap - Bolt: 5.8L (351 CID) 122-142 Nm
Oil Filter Insert to Cylinder Block Adapter Bolt 27-41 Nm
Oil Filter to Cylinder Block (4) -
1/2 turn after gasket contacts sealing surface.
Oil Inlet Tube to Oil Pump Bolt 5.0L/5.8L 16-24/14-20 Nm
Oil Pan Drain Plug 20-34 Nm
Oil Pan to Cylinder Block - Bolt 5.0L/5.8L 8-12/12-15 Nm
Oil Pump to Cylinder Block - Bolt 30-43 Nm
Oil Inlet Tube to Main Bearing Cap - Nut 30-43 Nm
Pulley to Damper Bolt 47-68 Nm
Rocker Arm Fulcrum Bolt to Cylinder Head 24-34 Nm
Spark Plug to Cylinder Head 5.0L/5.8L 7-14/14-20 Nm
Thermactor Pump Bracket to Cylinder Block Bolt 41-61 Nm
Thermactor Pump Pivot Bolt 30-43 Nm
Thermactor Pump Adjustment Arm to Pump 30-43 Nm
Thermactor Pump Pulley to Pump Hub 15-20 Nm
Valve - Rocker Arm Cover Bolt 5.0L/5.8L 8-12/4-7 Nm
Vacuum fitting/Plugs to Intake Manifold W/Teflon Tape. 8-14 Nm
Water Outlet Housing Bolt 12-16 Nm
Water Pump to Cylinder Block Front Cover Bolt 16-24 Nm
Distributor Hold-Down Bolts 23-33.9 Nm
Distributor Cap Hold-Down Screws 2.0-2.6 Nm
Distributor Rotor Hold-Down Screws 2.8-3.9 Nm
TFI Ignition Module Mounting Screws 1.7-4.0 Nm
Motorcraft 7200 V V Carburetor (5.8L) Version - -
Throttle Plate Screws (Before Staking) 1.1-1.7 Nm
Choke Control Diaphragm Cover Screws 1.5-2.1 Nm
Choke Cap Retaining Screws (If So Equipped) Breakaway
Venturi Valve Diaphragm Cover 1.7-2.5 Nm
Feedback Motor 11-14 Nm
1/8 Inch Pipe Plug Fuel Inlet Boss 7.9 Nm
Venturi Valve Cover Plate 2.7-4.0 Nm
Upper Body to Main Body Screws 2.7-4.0 Nm
Main Body to Throttle Body Screws 2.7-4.0 Nm
Air Cleaner Stud 8-12 Nm
Carb. Assy. to Intake Manifold 16-20 Nm
Fuel Filter Retaining Nut 10.2-14.1 Nm
5.0l SEFI Version - -
Lower Intake Manifold to Head 31-34 Nm
Air Supply Tube Clamps 1.7-2.6 Nm
Upper Intake Manifold to Lower Intake Manifold Bolts 16-24 Nm
Throttle Body to EGR Spacer and Upper Intake Manifold 16-24 Nm
Air Bypass Valve to Throttle Body 8-11 Nm
Throttle Position Sensor to Throttle Body 1.6-1.8 Nm
Fuel Pressure Regulator to Fuel Rail Assembly 3-4.5 Nm
Fuel Rail Assembly to Intake Manifold 8-12 Nm
Throttle Cable Bracket to Manifold 11-13 Nm
Use 2CarPros anytime, we are here to help. Please tell a friend.
Aug 25, 2022 at 4:51 AM
