engine rebuilding
FORD MUSTANG
MACKIETDMF
I am rebuilding the engine in my '65 Mustang. It has a 289 with 3 dueces. I inherited this car about 2 years ago, the man that built the car has about $9000 tied up in this engine. Recently the moter overheated and began knocking. I don't want to take any chances of destroying the moter all together so I am going through it and replacing bearings rings and such. I have heard many stories about people who have taken their motors and heads to have them vatted and wound up getting different parts back than the ones they dropped off. I had an article at one time with a recipe for a engine degreasing sovent that could be mixed up and used fairly safely by do-it-yourself people. I cannot find this article, could you recommend a solvent that can be readily purchased or do you happen to know of a home recipe I could use?
Thank you, Mackie McElreath
Jun 10, 2006 at 12:30 AM
RUGBYRULES
  • 5 POSTS
the knocking could be one of your cylinders broke or maybe a bad vavle. You can check this by starting the car and letting it idle and putting a long screw driver (doesn't matter phillips or flat head) on the vavle covers or on the cylinder head nad around the engine. This also helps find loose tapets. I have a knocking sound in my truck and its a cylinder. But don't over react!
Jul 27, 2006 at 4:38 PM
TCOOPER
  • 8 POSTS
Can you get me the firing order for the 289? I need as much info as you can give.I have an 82 with a 289 in it and Ineed to get it back in time. The owner pulled the bis tributor and did not mark any thing. You can email me at t_bone_racer@yahoo.com.
Aug 31, 2006 at 1:55 PM
