1990 Ford Mustang Rough Idle O2 Codes
RONSMUSTANG
I have a 1990 Mustang 5.0 with about 75,000 miles on it.
When I start it, it won't continue to run unless I play with the accelerator. then after it's warmed up a bit it runs, but roughly. It also sometimes pops like a carburator on acceleration.
Codes 91 and 41 on bank 2 come up on an analysis. I am guessing an oxygen sensor?
Ron
I did donate through paypal. Hope you got it!
Apr 24, 2007 at 11:43 AM
2CARPRO JACK
  • 11,533 POSTS
Yes, those are both o2 sensor codes. If there arent any mechanical problems with the engine, I would start there
Apr 25, 2007 at 12:51 AM
SERVICE WRITER
  • 9,123 POSTS
For what it matters, I ran through to trouble tree on it, not that is always the answer to a problem :roll:
But it starts with checking the fuel pressure to make sure it's in spec. and holds for 60 seconds with key on engine off. I think the spec is 35-45 psi?, but don't recall.
Apr 25, 2007 at 2:29 PM
Suggested Repair
Confirm there are no mechanical engine problems, then check fuel pressure with the key on and engine off to verify it is in specification and holds for about 60 seconds. If fuel delivery checks out, diagnose the bank 2 oxygen sensor circuit indicated by codes 41 and 91.
Conversation Summary
A 1990 Ford Mustang 5.0 with about 75,000 miles stalls unless the accelerator is used at startup, then runs roughly once warm and sometimes pops on acceleration. Codes 41 and 91 on bank 2 were retrieved. One expert identified both as oxygen sensor codes and recommended starting there if no mechanical problems are present. Another noted the diagnostic tree begins with verifying fuel pressure is in specification and holds for 60 seconds with the key on and engine off, though the exact pressure range was not confirmed.
