1993 Ford Mustang How much oil pressure is too much?
1993 FORD MUSTANG
20 MILES • V8 • 2WD • AUTOMATIC
BANSHEEMAN730
I have a 93 mustang with a wound up 306 that I just rebuilt. During the rebuild I Upgraded to a high volume oil pump with a 7 quart deep pan as well...When the car is at idle im right at 60 pounds of pressure but when you tach it up it jumps all the way to 80 pounds...Is this too much or is this normal ?
Mar 14, 2009 at 3:00 PM
MERLIN2021
  • CERTIFIED EXPERT
  • 17,250 POSTS
80 psi isnt bad...if it gets too high the relief valve opens, or you blow the oil filter apart.
Mar 14, 2009 at 3:03 PM
BANSHEEMAN730
[quote:51a51fbd24="merlin2021"]80 psi isnt bad...if it gets too high the relief valve opens, or you blow the oil filter apart.[/quote:51a51fbd24]How much would you think is too much?
Mar 14, 2009 at 3:09 PM
MERLIN2021
  • CERTIFIED EXPERT
  • 17,250 POSTS
Well if it goes much above 80 without the relief valve opening, its gonna blow! But it seems at 60 psi at idle with a warm engine, you have a real tight engine there! As it wear or should I say breaks in, it should drop a few pounds too...The spec on a 302 5.0 is 40-60 at 2000 rpm at normal temp, so you are in the park!
Mar 14, 2009 at 3:53 PM
