OK guys, thanks for all your help. I finally got this thing fixed and out of the "COMA"
After spending approx. $300 worth of parts; ECM, crank sensor, timing belt, coil packs, wires, spark plugs, TPS, EEC relay and lots of elbow grease, I decided to check every wire in the wiring harness. So it turned out to be a connecter behind the engine that connects power to the injector harness from the PCM and EEC relay. The 5 pin connecter was so corroded and also had a couple of missing pins and one being the +12 volt feed, I have no idea how this thing was even running previously. One thing I have to say though is, it's running better than ever. Oh well, it should be good for another 100K. LOL thanks again!
The silver bullet lives again!
Tuesday, March 13th, 2018 AT 8:26 PM
