Engine not starting
151,207 MILES • 4 CYL • AUTOMATIC
MAXLIFTED
I recent changed half of my engine haven parked the vehicle for 7months. When the new half engine was installed, the vehicle refuses to start but will be cranking. when fuel is forced into the engine (soughing) the engine will start but onnce the fuel forced into the engine finishes, the engine will stop. When the ignition is turn off and the key removed, all the dash board lights will still be on. These dash board lights only goes off when one of the fuses in the banet is removed or the battery terminal removed. The vehicle still would not accelerate after starting my forcing fuel into the engine. the nozzle light refuses to show light when tested with test lamp.
Please, I need help on what to do.
Aug 25, 2016 at 4:15 AM
HMAC300
  • 48,601 POSTS
try resetting security system if no manual look online for your car on how to do it.
Aug 25, 2016 at 5:01 AM
MAXLIFTED
there is no security in the car
Aug 25, 2016 at 5:23 AM
MAXLIFTED
some auto electricians are suspecting it to be that the brain box (car computer) is dead. could this be truth?
Aug 25, 2016 at 5:25 AM
HMAC300
  • 48,601 POSTS
ya know there have been security systems in all cars sold in North America since at least 1997 so do what I said with the security systems being not run for that long it probably has engaged especially if anything on battery was disconnected. it could be pcm but I kind of doubt it it ran prior so it should now. security systems shut down fuel or ignition sometimes both
Aug 25, 2016 at 5:57 AM
MAXLIFTED
did that but still didnt start. Could it be the nozle earth wires behind the manifold?
Aug 28, 2016 at 2:45 AM
HMAC300
  • 48,601 POSTS
scan for codes to see wha tis wrong or if anything shows up via scanner
Aug 28, 2016 at 4:04 AM
