Crank no start
MICHAEL_CAT_UK
  • 7 POSTS
I had all the glow plugs replaced and the garage said that the car works when jump started and that replacing wit a heavy duty battery would help.
However, I noticed that the when I got home and tried to restart, the pre-heating sign which normally appears and goes out after a couple of seconds, was not appearing at all.
Any ideas? Seems to me that this could be the problem, not the battery. It's just takes a couple of times to start maybe because the plugs aren't warming.
Wednesday, March 25th, 2020 AT 1:09 PM (Merged)
JMCCCC
  • 2001 RENAULT LAGUNA
Electrical problem
2001 Renault Laguna 4 cyl Front Wheel Drive Manual 90.000 miles
hi can you help me with problem please, just recent my laguna would not start and I tried to change fuse, eversince the speed metre wont work plus the abs and parking light wont go of I tried to change fuse but when I let parking break down the fuse blows
DAVE H
  • 13,384 POSTS
Check the wiring for the parking brake switch ! You may have a faulty dash display unit. Renault dealer should be able to check using their diagnostic scanner !
JOYBELL1
  • MANUAL
  • 120,000 MILES
When I insert the key-card and press the starter button nothing happens.
KHLOW2008
  • 41,814 POSTS
Have the battery tested. Do the dash lights come on?
JOYBELL1
Battery okay and the lights come on.
KHLOW2008
  • 41,814 POSTS
You would have to check the brake lights to see if they are working. Next is the gear shift. Try shifting it to "N" and check if you could crank.
Another thing to check would be the starter.
JOYBELL1
The brake lights are working. Tried the gear shift but would not crank.
Do you mean the starter button or starter motor?
Wednesday, March 25th, 2020 AT 1:10 PM (Merged)
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,363 POSTS
The starter motor, here is a way to see if the starter motor is bad:
Please run this test and get back to us so we can continue helping you.
Best, Ken
