ENGINE NO POWER
225,314 MILES • 1.4L • 4 CYL • TURBO • AUTOMATIC
AMORY
When engine starts the revs is at 1800rpm and have to wait until rpm decreases to 800rpm about 3 to 5 minutes wait before driving. If try to drive when revs is still at 1800rpm engine stalls and stops.Change coils last year .
Apr 21, 2021 at 2:37 PM
This sounds like a possible vacuum leak and as the engine warms up the leak goes away.
Here is a guide that talks about high idle:
https://www.2carpros.com/articles/engine-idles-too-high
I would suggest focusing first on a vacuum leak. However, you need to do this testing when the engine has the high RPM. Once the RPM drops the leak is most likely gone.
The other possible cause the the PCM thinks there is more air coming in which would be a MAF/MAP sensor issue. So let's check for codes as well
We don't have a manual on this vehicle as it is not offered here in the USA but I think we can still uncover the issue with running through this material.
Let us know what questions you have. Thanks
Apr 23, 2021 at 2:41 AM
