Engine does not start
123,867 MILES • 3.0L • 6 CYL • TURBO • 2WD • AUTOMATIC
DAUNTE
Hi, my car will crank but not turn over and there is no power in the interior but the hazard lights will turn on when the button is pressed. I checked the spark plugs and they are good, I got a new battery, and I can smell fuel when I crank the car. My dad thinks it is something to do with a cable that was disconnected when we tried to take of the plenum to change the intake manifold gasket. I hope someone can help because I don’t know what to do.
Mar 30, 2021 at 5:32 AM
  • 110,251 POSTS
If you were smelling gas when it wouldn't start, it sounds like you lost spark to the plugs.
First, I need you to check for spark. Here is a link that explains how it's done:
Now, I don't know if there were any indicators of trouble before, but if it lost spark and it happened suddenly, it could be a faulty crankshaft position sensor. Take a look through this link and let me know if it mirrors what you have experienced:
Let me know. Also, if the battery has been disconnected, chances are there are no diagnostic trouble codes stored anymore. However, here is a link that explains how to check for them just in case:
https://www.2carpros.com/articles/lexus-trouble-codes-obd1-1990-1995-code-retrieval-procedure
Mar 31, 2021 at 1:39 PM
