Headlights not working and dash lights go dim
JODIKILCREASE
I have replaced the battery with another one from another vehicle we have. It starts up that vehicle ok so I'm sure the battery itself is ok. But I will for sure check the terminals and the wiring by the air filter first thing in the morning. I will be sending u some money through as son as I get a net spend card to do that with. Lol. U r awesome and thank u so much for ur quick response. Wow is all I can say.
Thursday, June 18th, 2020 AT 1:28 PM (Merged)
KNOWLEDGE IS POWER
  • 1,136 POSTS
Glad I could give you help! Don't worry about money til its going! Lol!
CGABRIEL
  • 1998 CHEVROLET MONTE CARLO
  • 3.1L
  • 6 CYL
  • 180,000 MILES
The headlights on my 1998 Monte Carlo won't work. I've replaced the bulbs. I'm trying to find the headlight relay but its not located inside the relay boxes under the hood. Where is this? If that doesn't work what other problems can cause this and how do you fix it?
HMAC300
  • 48,601 POSTS
Scan for codes it may be the DRL module as headlights go through that. A pro will need to do it. It cold also be the multi function switch but get it scanned first.
JWILSON64
  • 6 CYL
  • FWD
  • 220,000 MILES
My low beam head lights won't come on. The high beam side works as it should. I can't find a seperate fuse for the low beam headlights. I checked all the fuses and bulbs I could and they are good.
TOOOMANYTOYS
  • 513 POSTS
Check for power at the bulb socket and work your way back. Multifunction switch are a common cause.
JWILSON64
Where is the multifunction switch located?
TOOOMANYTOYS
  • 513 POSTS
Its located on the steering colum. It controls the high beams on and off, and you turn signals.
KG051H
  • 1996 CHEVROLET MONTE CARLO
  • 6 CYL
  • 145,000 MILES
When turning on my head lights, my dash lights and parking lights will not work but head lights come on. I checked the fuses and change the head light switch what else can it be
DOCFIXIT
  • 18,828 POSTS
Problem maybe in dimmer switch. Car have DRL or SEO?
KG051H
Head light and dimmer switch is all one unit
