All electrical turns off when shutting the door sometimes
77,000 MILES • 2WD • AUTOMATIC
SHAWN MULLEN
When shutting door sometimes all electrical will cut out.
Sep 27, 2018 at 3:51 AM
HARRY P
  • 2,292 POSTS
To me it seems like you probably just have a loose ground wire or battery terminal. Or maybe you just need to clean the terminals.
How to clean terminals - https://www.2carpros.com/articles/everything-goes-dead-when-engine-is-cranked
If that is not it, then follow those cables to wherever they go and make absolutely sure that the connection surfaces are very clean and tight. Dirt and/or looseness will cause all sorts of problems.
Let us know what you find.
Sep 27, 2018 at 6:02 AM
