1970 Chevy Camaro 1970 camaro troubles
TBCARDIST88
1970 Chevy Camaro V8 Automatic
ok, i have a 1970 camaro. about 2 weeks ago i went on vacation and prior to the trip, the car was running fine. during the vaction, i had a friend watch over the house and start the car up every other day for a few minutes because i didnt want it to sit. he tells me that after a few days, the car wouldnt start and he had to jump it. i said the its probably jus the battery. well, i come back and there is absolutely no electrical power going to the car at all. the battery is fine and so in the alternator. fuses are good. when i try to start it i here nothing at all. the radio doesnt turn on and neither do the lights. ive been told that its the starter, ground cable, starter harness wires, ignition switch, etc. but honestly, i dont know.
Jul 1, 2009 at 6:57 AM
DOCFIXIT
  • 18,828 POSTS
All those are probable faults take a test light or meter and start tracing power. Post back results will advise.
Jul 1, 2009 at 7:18 AM
TBCARDIST88
thank you. but can you explain how im suppose to do that? i have a voltage meter and the voltage at the battery is good. i just dont know how to test the other areas of possible error. sorry
Jul 1, 2009 at 7:55 AM
