Electrial issue
  • 109,885 POSTS
That sounds like a plan. I have to be honest. When you said closing the rear door caused it to work again, I was a bit confused. I can't picture anything in that area that would cause the issue. However, I guess a vibration can do it.
Let me know and take care of yourself.
Thursday, February 13th, 2020 AT 6:49 PM
SUNDESA
  • 15 POSTS
Hi Joe,
This issue started again and unfortunately I tried all the tested ways which previously solved my issue.
I need your expert advice now, to start tracking the root cause. From where shall I start and which areas to investigate?
Really Thanks
Thursday, February 13th, 2020 AT 10:12 PM
  • 109,885 POSTS
Start by checking all connectors and wiring harnesses on the transmission. Make sure no pins are pushed in or corroded.
Friday, February 14th, 2020 AT 2:05 PM
