I would like to know if the car's ECU is bad. Several people told me the ECU may be bad, is there any test to see if this is true?
Thanks
Jul 18, 2016 at 12:16 AM
KRYPTECLIPSE
MEMBER
By the way, i get code P0601.
Jul 18, 2016 at 12:18 AM
HMAC300
✓Experienced Mechanic
that is an internal controller problem on ecu. some guys have had luck with reprogramming computer and other guys have found that the crank sensor has caused the problem. pcm 's can be rebuilt for a cheaper alternative but must have security programmed by a mechanic into it.
Jul 18, 2016 at 2:38 AM
KRYPTECLIPSE
MEMBER
the computer is not sending power to the relay of the coil. it is also interfering to the relay of the fuel pump. this is is what my mechanic is saying. thanks in advance
