1999 Dodge Caravan Powertrain Control Module
BOXERSD
Computer problem
1999 Dodge Caravan 4 cyl Front Wheel Drive Automatic
I have a 1999 Dodge Caravan. Someone aparently sent a current in, at the (ECT) connector. Directly from the vehicle battery. Now it won't cranck or turn over. I beleave the PCM is faulty. Please help.
Jul 3, 2010 at 4:53 AM
  • 75,988 POSTS
Check what's causing it not to start could be fuel or spark-Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Jul 3, 2010 at 5:01 AM
