ECM problem
JOE1953
  • 686 POSTS
No I havn't replace the thermostat yet the check engine light don't stay on all the time its just on an of sometime why does it come on and go of sometime if the thermostat is bad?
Monday, June 3rd, 2019 AT 7:38 PM (Merged)
SATURNTECH9
  • 30,869 POSTS
Because sometimes the thermostat holds back enough coolant flow till it opens for the code to not set and sometimes it doesn't. You have a bad thermostat I have replaced them before for that car and many other different makes and models for that code.
JOE1953
  • 686 POSTS
The engine is not over heating do I need special tool to replace the thermostat?
SATURNTECH9
  • 30,869 POSTS
It's not a overheating code it's a running too cold code. No special tools needed.
JOE1953
  • 686 POSTS
I use my scan tool to read codes on a 1996 chevrolet pickup 1500, 2003 lincoln town car and it read the codes but I use it on a 2007 toyota camry, 2006 saturn and I get a link error do I need to buy a new scan tool? The autel A1319 scan you have how much does it cost and where can I buy it? I want one that is very unexpensive I would like to get one that read live engine data like the one you have.
SATURNTECH9
  • 30,869 POSTS
Autel AL319 AutoLink OBD ll Code Reader https://www.amazon.com/dp/B013BJY12E/ref=cm_sw_r_cp_apa_5VB3xb8HNQVHK
It's on Amazon it's got a color screen and reads some live engine data not all engine data.I like it I accidently bought a China knock off and it worked a couple of times then quit even turning on.
