1994 Eagle Vision Power Steering Left
RONPISCHINGER
power steering works when turn right but not when turn left any ideas?
Feb 11, 2006 at 9:13 AM
2CARPRO BOB
  • 45 POSTS
Your symptoms suggest that your power steering rack is faulty. Here is how to change the steering rack out so you can fix the problem. Check out the images (below). Let us know if you need anything else.
Feb 12, 2006 at 12:16 PM
Suggested Repair
Replace the faulty power steering rack.
Conversation Summary
The owner of a 1994 Eagle Vision reported that power steering works when turning right but not when turning left. The expert said the symptoms indicate a faulty power steering rack and recommended replacing the rack.
