1996 Eagle Talon MY CAR LOOSE THE SPARK FOR A MINUTE WHEN I
17,000 MILES • 4 CYL • 2WD • MANUAL
LANDEROS71
HI, IM NEW HERE, I HAVE A 1996 EAGLE TALON IS A 2.0 NON TURBO ENGINE THE CAR RUNS GOOD, NO CHECK ENGINE LIGHT, WHEN THE TEMPERATURE IS ON NORMAL SOMETHING HAPPENS WHIT THE SPARK IN THE COIL-PACK THERE IS NO SPARK, I NEED TO WAIT ABOUT A MINUTE TO START THE ENGINE AGAIN, THIS REPEATS AND REPEATS OVER AND OVER WHEN IM RUNNING I ALREADY REPLACE THE COILPACK AND THE CONECTOR I WAS THINKING ON THE CAM SENSOR BUT IM NOT SURE BECAUSE THERE IS NOT FAULT CODE ANY IDEA? THANKS
Dec 1, 2008 at 9:41 AM
BMRFIXIT
  • 19,053 POSTS
Sounds as a bad crank sensor
check and or replace it
also check ASD relay
Dec 1, 2008 at 9:47 AM
LANDEROS71
Hy im still trying to find the problem, do you know the location of the ASD relay?, and also the crank sensor is there any test i can do? thanks.
Dec 2, 2008 at 5:00 AM
BMRFIXIT
  • 19,053 POSTS
NON -Turbo crankshaft position sensor is located on side of engine ,near oil filter
Non-Turbo ASD relay is located on cowl ,at rear left of engine compartment by the master cylinder
I think u have 3 relays
ASD relay is the mid one
just replace it with a similar one
I would suspect a bad crank sensor
Dec 2, 2008 at 5:18 AM
LANDEROS71
I hope not bother much, i really apreciate alot what are you doing i really love mechanic but this type of case really fascinates me but somethimes can became a headache, finally i would like to know if is not to much, what do you think about the PCM could be possible the failure? there is no faulty codes. Thanks!
Dec 2, 2008 at 1:48 PM
BMRFIXIT
  • 19,053 POSTS
Every thing is possible
but I do Not think its the PCM
more test needed to determine if its the PCM
have you replaced the crank sensor yet!
Dec 2, 2008 at 10:00 PM
LANDEROS71
Hy there, i already replace the ASD relay, also the crank sensor, and my car still the same, i have make new tests, when there is no spark i chek the voltage in the cam, in the ASD, also in the coi pack, and there is no voltage , then i wait a while and is back any other idea? Thanks
Dec 11, 2008 at 4:25 PM
