no spark
200,000 MILES
JOHN PACE 56
  • 6 POSTS
my son has a 1995 eagle talon and has replaced the crank sensor and and a 300 dollar computer and fuel pump everything was put back the way it came out please help him he has over 900 in parts and only paid 400 for the car
May 2, 2013 at 9:06 AM
CARADIODOC
  • 34,414 POSTS
The first thing is to determine if the automatic shutdown (ASD) relay is turning on. Look for the wire that is the same color at every injector, the ignition coil, and the alternator. Measure the voltage on that wire at any of those places. A test light works best but a digital voltmeter will work if you watch it closely. You must see 12 volts there for one second after turning on the ignition switch, then it will go back to 0 volts. The fuel pump should also run for that one second.
Next, that voltage must come back during engine rotation, (cranking or running). That will tell us which way to go next.
Also check for diagnostic fault codes. Chrysler makes that easier than anyone else. Cycle the ignition switch three times from "off" to "run" within five seconds without cranking the engine. Wait for the Check Engine light to turn off, then count its flashes when it starts flashing. There will be from one to four flashes for the first digit, a pause, then one to nine flashes for the second digit. There will be a longer pause then the next two-digit code will flash. If you get code 12, that can be ignored. Code 55 will be the last one and is ignored.
May 2, 2013 at 9:24 AM
