Door locks
238,000 MILES • 4.0L • 6 CYL • AWD • AUTOMATIC
ERICELLEGOOD
Door locks will not lock or unlock by keypad or key-fob. the dome light will come on or go off with key-fob it was about one time a mouth blowing a fuse #38 roll 1 second fuse. now I put fuse in it blows it . It is not wires to doors or door lock accumulator those are fixed door no door ajar light all doors closed. Where do I look next? wire is grounded somewhere.
Aug 9, 2017 at 11:56 AM
  • 55,658 POSTS
It sounds like you have a door lock actuator that is shorting out. The problem is figuring out which one. I would start by removing the door panels (1 at a time) and disconnecting the lock acuators and then replacing the fuse. Do this trail and error method until the fuse doesn't not blow.
Cheers, Ken
Aug 14, 2017 at 1:29 AM
