When you first turn the key to run before you turn the key to start, the fuel pump should run for about two seconds. If not, check the fuel pump fuse and then put your finger tips on the fuel pump relay and feel if it clicks when the key is turned to run. If it does and the fuel pump did not run for two seconds, try a new fuel pump relay.
Sep 3, 2020 at 2:40 AM
