does not start
120,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
DANIEL CRISCO
I went to start my car and it would not start at all. Also when I plugged in my scanner tool with key off I had power to it. When I turn the key to the run position I lose power to the code reader tool. I have checked three times all the fuses and relays and do not find the problem.
I even removed the battery and all the ground cables even those to the body and cleaned all the connections and checked their continuity.
Seems to be a problem with a ground somewhere as I mentioned I lose power to the code reader tool when I turn the key to the run position and lose power to the code reader tool. .
Fuel pump reset switch is not tripped either....
got any idea?
Please help...
Daniel M Crisco
dcrisco9@gmail.com
615 415 3310
Mar 18, 2017 at 3:53 AM
HMAC300
  • 48,601 POSTS
ty a security system reset probably when you disconnected battery did it see our link.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Mar 18, 2017 at 7:01 AM
DANIEL CRISCO
This no start issue happened after I drove car last. Next morning I went to start and the engine turns over or cranks but no start at all. I had not disconnected the battery at that point so I dont think its the security system.
Remember. ..as I hook up the scan tool to the port it comes on untl I turn the key on position and lose scanner at that point or power to it.
now the scanner tool has no power at all when I plug in. Its like I lose ground or lose power somehow to the scan tool or the port..
still scratching my head.........
Mar 18, 2017 at 11:37 AM
HMAC300
  • 48,601 POSTS
any scannerwill power up with key off if it is going out then there is aconnection problem or a blown fuse under hood. if it still won't power up try another scanner as some will ldo that. you should still try security , also check fuel pressure with a gauge auto parts rent it . to verify it's fuel problem shoot choke cleaner into throttle body if car starts then it's fuel. see link.
Mar 19, 2017 at 12:57 AM
