1994 Dodge Van Plenty of crank no spark
23,400 MILES • V8 • 2WD • AUTOMATIC
JPTWOTIMES
  • 5 POSTS
Idon't know what to do next. From time to time, some times daily sometimes a day or to will pass, but always come back. Short drive long drive no matter while driving city or hiway it just shuts off, no spudder just shuts off. Then maybe an hour maybe not til next morrning it starts first try. I've changed coil,fuel firter,crankshaft sensor. I could really use some help. THANKS Jptwotimes
Oct 6, 2009 at 9:47 PM
JDL
  • 16,098 POSTS
When the problem occurs, you have no spark at the plugs, engine cranking? Are you missing anything else? How is the fuel pressure?
When the problem occurs, check the coil primary circuit, injector also, dark green wire with orange wire should be hot, engine cranking. any codes?
Oct 7, 2009 at 7:12 AM
