1990 Dodge Van no spark
150,000 MILES • V8 • 2WD • AUTOMATIC
MIKEPETERSENJR
If you hard wire the coil it has spark.What could be wrong in the system
mike
Dec 14, 2008 at 4:25 PM
  • 75,988 POSTS
Inspect and test the ASD relay it powers the coil direct
Dec 14, 2008 at 8:03 PM
VIPERTEK
  • 40 POSTS
check crank sensor very common
Jan 9, 2009 at 2:41 AM
  • 75,988 POSTS
If you have to hard wire it then your not getting power to the coil. If the coil don't have power nothing is gonna happen irregardless if the rest of the ignition components are working such as the pick-up coil/control module/cam and crabk sensors.
Jan 9, 2009 at 5:23 AM
