1997 Dodge Ram 1500 Uneven Front Brake Wear Fix
ALVIJ
I have a 1997 Dodge 1500 ram long bed with 5.2 L 169000 miles. My problem is this I change the brakes about every 3 months, the passenger side wares faster then the driver side by 80% or more. I've changed the calibers with no change. Any help would appreciated.
Aug 15, 2007 at 2:20 PM
MERLIN2021
  • 17,250 POSTS
If you already changed the calipers, you will need new brake hoses, do both sides. Get a good quality pad such as ceramic, the last longer and less prone to squeal. Adjust your rear brakes, and make sure the wheel cylinders, or calipers back there aren't leaking!
Aug 15, 2007 at 11:57 PM
Suggested Repair
Replace the brake hoses on both sides, install quality ceramic pads, adjust the rear brakes, and check the rear wheel cylinders or calipers for leaks.
Conversation Summary
The owner of a 1997 Dodge Ram 1500 reports front brake pads wearing out about every three months, with the passenger side wearing much faster than the driver side. Replacing the calipers did not help. The expert recommends replacing both brake hoses, using ceramic pads, adjusting the rear brakes, and checking the rear wheel cylinders or calipers for leaks.
