1990 Dodge Ram Brake Pedal to Floor
THORDX
I have a 1990 dodge ram 4X4 with about 100,000 on it the engine is the 1800. Here is my problem. We we purchased the truck there was no break pedal when it is running. All the breaks, rotors cylinders,lines, rawl unit, master cylinder and Vacum assit unit have been replaced. The lines have no air in them when we try to bleed them. but when you start the truck the pedal goes to the floor. Could the be a vacum pump problem? How can i check the vacum pump. I am lost at this point any direction you could give would help
Thanks
Aug 29, 2007 at 5:05 AM
WRENCH
  • 57 POSTS
Was there any feel at all on the pedal, if nothing and feels like its just hanging there recheck the connection at the pedel, next I would check to see if the master cyl. was bleed first, than bleed the brakes starting with furthest away from master.
Sep 18, 2007 at 1:15 PM
Suggested Repair
If the pedal has no feel, recheck the connection at the pedal. Confirm the master cylinder was bled first, then bleed the brakes starting with the wheel farthest from the master cylinder.
Conversation Summary
The owner of a 1990 Dodge Ram 4x4 says the brake pedal goes to the floor when the engine is running, even after replacing the brakes, rotors, cylinders, lines, valve unit, master cylinder, and vacuum assist unit. Bleeding shows no air in the lines. The expert advises checking pedal feel and the pedal connection, then bleeding the master cylinder before bleeding the brakes from the farthest point.
