My ABS light is on and the brake pedal is soft yet there is no air in the brake lines. I can't find whats wrong.
Dec 5, 2007 at 4:14 AM
MERLIN2021
✓Experienced Mechanic
When you say soft, do you mean it goes to the floor if pressure is held on it? Spongy? Will pump up?
Dec 5, 2007 at 5:15 AM
Yep, you could still have air in the lines and more specific the ABS control valves. You must use a scanner to open the valves when bleeding the brakes, please go over this video to help you see what I am talking about.
