2000 Dodge Truck Dodge 1500 5.9 liter won't start
TPORT
  • 2000 DODGE TRUCK
  • V8
  • 4WD
  • 89,000 MILES
My engine will crank over but will not start. When you turn the key to the on position and you can hear the fuel pump start up. I also checked the valve on the fuel track and gas will come out when pushed. I am also getting fire when I checked the number 1 plug. What can I try next?
Monday, January 25th, 2010 AT 7:51 PM
Hi tport, Welcome to 2carpros and TY for the donation
Since you can hear the fuel pump come On-check the fuel pressure if its within specs and also check if the injectors are pulsing
Monday, January 25th, 2010 AT 8:34 PM
TPORT
Do you know the specs for dodge 1500 5.9 liter? How do I check to see if injectors are pulsing?
Tuesday, January 26th, 2010 AT 9:37 AM
At idle the fuel pressure should be 44-54psi and for the injector listen to it if its clicking or use a noid lite on the harness if its flashing the injector driver is working but not the injector-defective-
Tuesday, January 26th, 2010 AT 9:46 AM
