1995 Dodge 2500 160k
PLAGUEDU
Recently I have been having a proble with my truck dying. It started about two weeks ago. Though it was water in the tank so I got some gas for it and a bottle of drygas. Tried starting it and it wouldnt run. Tried about an hr later and it ran fine. Its been running fine everyday until today. I was driving around all morning. I stoped at Work for about 5min and left it running. When I came outside it was dead and I still cant get it to start. In the past year I have replace the Distibutor, Dis. Cap, Wires, Plugs, Coil, Fuel Pump (3 one sence I bought the truck) and crank shaft sensor. Do you have any Idea what it could be. I noticed the ground strap from the block to the firewall was broken in half. Could that be my problem?
Apr 16, 2007 at 1:10 PM
2CARPRO JACK
  • 11,533 POSTS
Did the dist. come with a new cam angle sensor? Is it missing fuel or spark when it wont start?
Apr 17, 2007 at 1:15 AM
PLAGUEDU
I put a spark tester on the coil and I get nothing, nothing, lil spark, lil spark, Big Spark, then it repeats, The distributor did come with a "Pick Up Coil" or what ever the technical term is. I was told that it might be because I used a napa distributor, instead of a mopar one, something about napa distributors dont hold up as well. I am getting fuel though to answer your question
Apr 17, 2007 at 10:50 AM
2CARPRO JACK
  • 11,533 POSTS
An OEM distributor might not be a bad call
Apr 17, 2007 at 10:53 AM
PLAGUEDU
Replaced the Tempature sensor, and the holafact switch in the distributor today, Still no change, Tried jumping out Auto Shutdown Relay and that did nothing as well. Any more suggestions?
Apr 18, 2007 at 9:50 AM
