2000 Dodge Truck Oil Fill Cap
2000 DODGE TRUCK
12,700 MILES • V8 • 2WD • AUTOMATIC
KRAGSDALE411
How do i remove the Oil Fill Cap to add oil to my truck? Can not get it off by Screwing it like my chevy truck :( Thanks In Advance, Kat
Apr 24, 2009 at 11:09 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:0fcf80ae6a="kragsdale411"]Engine Performance problem
2000 Dodge Truck V8 Two Wheel Drive Automatic 127,00 miles
How do i remove the Oil Fill Cap to add oil to my truck? Can not get it off by Screwing it like my chevy truck :( Thanks In Advance, Kat[/quote:0fcf80ae6a]
You can try using a large set of Channel Lock Pliers and turn it off. They will sometimes have a tendency to weld themselves in if they are not removed regularly. Just be very carefull not to break it. You may want the engine at Normal Operating temp or at least warm before trying.
Apr 24, 2009 at 11:17 AM
KRAGSDALE411
Thank-You Sooooooo Much for your help. I just purchased the Truck today and was checking fluids etc. I Suppose it is just stuck then, i'll keep trying. Hugz, Kat
Apr 24, 2009 at 11:22 AM
