1995 Dodge Truck Dodge Diesel Truck Starter
1995 DODGE TRUCK
228,000 MILES • 6 CYL • 4WD • MANUAL
LISALEWIS333
My 1995 Dodge Cummings Diesel 2500 would not turn off with the key, so I killed it. Now it won't start. Suspect starter went to ground? Would that cause it to do this?
Dec 5, 2009 at 3:02 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for the donation!
Although the starter may possibly be the culprit, it is more likely that you have a faulty ignition switch which is located in the steering column. You can remove and have the starter tested at most auto part stores for free.
Dec 5, 2009 at 12:20 PM
