given the coil and all plugs are getting spark.(Checked visually)
the timming is correct (checked TDC w/ position of roter in the distributor cap)
all the fuses have checked out.
I replaced the battery about a week ago.
The gas in the tank is fine(have run the truck for three days w/ the same Gas)
The engine Has been running fine.
AFTER STARTING AND MOVING THE TRUCK A SHORT DISTANCE. TURNED THE TRUCK OFF. TWENTY MINETS OR SO LATER THE TRUCK WOULD TURN OVER BUT WOULD NOT START.
ANY SUGGESTIONS?
SPONSORED LINKS
Tuesday, October 27th, 2009 AT 5:14 PM
