1994 Dodge 3500 cummins diesel PCM
1994 DODGE TRUCK
KEN SCHIBI
Randomly, more so when the weather is warm, the electronics of the entire charging system will go out. The tach quits, the over drive goes out, the charging system lights come on and the batteries drain quickly. If I turn the truck off and let it set awhile, it will generally correct itself and run fine. I can't think of anything other than the PCM mal-functioning. I have had it checked by numerous shops but they can,t figure it out because it doen't occur during their analysis. On shop thought it was the alternator and replaced it. Another shop thought it was the belt tensioner and replaced it. The truck still does it. Do you have any suggestions or solutions?
Apr 11, 2007 at 12:15 PM
KEN SCHIBI
I will consider the donation if the problem is solved.
Apr 11, 2007 at 12:19 PM
JOE SIMS
Ken, I am having the same problem with my 1994 Dodge, cummins.... I have put on new ignition switch on, new cam censor, and 3 computers, and my problem isn't fixed yet..... Did you get your problem resolved? and what did you have to do? Thanks, Joe Sims
Jan 13, 2011 at 1:08 PM
