1988 Dodge D150 No Start
HUE
I'm not sure what motor it has in it, but I do know it's a v8. On one side of the truck it says D100 and on the other side it says D150. I have had slow starts (engine cranks, but took long time to fire) for quite some time now, and it had gotten to the point that sometimes it would act like the battery was dead. It would just make a bit of a click when I turned the key. then a few minutes later, it would start like there was no problem. Now it wont start at all. It just acts like the battery is dead even when I hook it to another vehicle. I replaced the starter yesterday, but it still does not even try to start, just a faint click.
Thanks in advance for any advice.
Oct 18, 2007 at 5:47 AM
2CARPRO JACK
  • 11,533 POSTS
Need to test it to see if you are getting 12 volts to the starter. Could be a bad ground or positive battery cable
Oct 18, 2007 at 7:53 AM
HUE
Thanks, I will check both of those.
I had a friend turn the key while I was under the hood and it sounds like a relay or something on the driver fender makes a buzzing sound when the key is turned
Oct 18, 2007 at 7:58 AM
2CARPRO JACK
  • 11,533 POSTS
could be low system voltage
Oct 18, 2007 at 8:06 AM
HUE
Thanks for all you help. I got it going. I had recently changed out the battery because I figured it may be my problem. It did not change anything. However, the one thing I never did (even while changing the battery) was clean the battery connectors..........There was a thin coating that had built up where they make contact with the battery posts. Your low system voltage comment made me go test things with my volt meter. Once I determined that I had different voltage on the connector than I did on the post itself, I took them off and cleaned them. I did have to jump start it, but this time it started and I have had no more problems like this.
NEXT TIME I WILL START WITH THE SIMPLE THINGS!
Oct 22, 2007 at 4:32 AM
Suggested Repair
Clean the battery posts and cable connectors, then verify full system voltage. If voltage is still low, check the positive battery cable, ground, and 12 volts at the starter.
Conversation Summary
A 1988 Dodge V8 pickup (badged D100/D150) cranked slowly, then only clicked and would not start even when jumped. A new starter and battery did not help. The expert advised checking for 12 volts at the starter, a bad ground or positive cable, and low system voltage after a fender relay buzzed. The owner found a coating on the battery connectors, cleaned them, jump-started the truck, and the no-start problem was resolved.
