Dodge Stratus 2002
CASEY
Hi I have a 2002 Dodge Stratus. My heater/ac fan only works on "high". How do I tell if I need a blower motor, or a blower motor resister? Also..I have heard that this is a relatively easy part to fix myself..any pointers? Thanks!
Nov 11, 2006 at 9:44 AM
JAIDDRAGON
I have a 1999 Dodge Stratus that has the same problem...just read an earlier post that says probably the switch is bad, common problem apparantly...
Nov 24, 2006 at 3:55 PM
1BIGG1
  • 61 POSTS
it does seem to be a common problem in dodges, ive never had a problem with my personal vehicle but i would assume its the switch, the contacts inside it could be broken or tarnished.
Nov 25, 2006 at 9:28 AM
BOOTDOG
  • 665 POSTS
if it only works on high then you need to replace the resistor. it's either located by the blower motor or right behind the dash at the very top in the center just right below the windsheild
Nov 26, 2006 at 8:28 AM
