Dodge Stratus Blower High Only
FIVER5TER
Blower motor is working on high only, know that it is the resistor, but exactly where is this located?
Jan 28, 2007 at 5:56 AM
SERVICE WRITER
  • 9,123 POSTS
Passenger side bottom of the HVAC plenum
See diagram below for location
Jan 28, 2007 at 11:51 AM
MIKE MCCORMICK
Heater problem
1998 Dodge Stratus 4 cyl Two Wheel Drive Automatic
part #1-04885844AA
the fan works on high only, dealer replaced resistor
in July
Dec 31, 2018 at 2:28 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
check for faulty blower motor relay
BAS0511
my heater only works on high so i got a new blower moter resistor but i can't find where it is on the car to replace it. looked ynder dash and behind glove box without any luck.please help
ZACKMAN
  • 4,202 POSTS
Yes it is there. Just next to the blower motor. Look at this picture.
https://images.2carpros.com/forum/automotive_pictures/55316_blowerrepair_1.jpg
And go to www.stratusphere.us/blowerrepair.html for instruction.
TTBUMPS
I need to know where the blower resistor is located on a 2000 dodge stratus so that i can replace it
OBXAUTOMEDIC
  • 3,719 POSTS
[quote:010539cc61="ttbumps"]Heater problem
2000 Dodge Stratus 6 cyl Front Wheel Drive Automatic 120000 miles
I need to know where the blower resistor is located on a 2000 dodge stratus so that i can replace it[/quote:010539cc61]
It is located in the duct work under the passenger dash....
RADARR111
Electrical problem
1998 Dodge Stratus 4 cyl Front Wheel Drive Automatic 197564 kms
I'm asking how to replace the blower resistor. I have been told it is in behind the dash board. Is this correct? and if so, the procedure for replacing it.
thanks
  • 75,988 POSTS
The blower motor resistor is located on the lower right side of the heater housing. REMOVAL Remove lower right underpanel silencer/duct. Disconnect wiring connectors on blower motor resistor. Remove blower motor resistor retaining screws. Blower Motor Resistor
https://images.2carpros.com/forum/automotive_pictures/12900_b_18.jpg
Pull blower motor resistor out of heater housing. INSTALLATION For installation, reverse the above procedures. https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
MTSMGS
2000 dodge stratus se 2.5l blower and temp controm problem
Hi, The afore mentioned vehicle has only (4) highest speed working on blower switch. Also, temp knob doesn't regulate the temp at all. Where is the resistor located for the blower and how do I fix the temp switch. Thank you very much for your time and input!
SERVICE WRITER
  • 9,123 POSTS
https://images.2carpros.com/forum/automotive_pictures/30961_strres_1.jpg
https://images.2carpros.com/forum/automotive_pictures/30961_strres1_1.jpg
MTSMGS
Thanks for the advise. I changed the resistor and now all 4 fan speeds work, however, the temp control knob still doesn't change the temp of blower air. Can't hear any sound when i turn it, (like a door opening and closing) control motor for temp switch?
Also not sure where it is . Any ideas would be appreciated..
hanks again for your help.
Mike
SERVICE WRITER
  • 9,123 POSTS
I assume you tried to calibrate it? If not do so first.
https://images.2carpros.com/forum/automotive_pictures/30961_mode_1.jpg
https://images.2carpros.com/forum/automotive_pictures/30961_mode1_1.jpg
JGUMINA
It just happened today. when I select the speed of the fan the only time the fan works is in high speed only when I turn the knob selection to high it has off . It that is the fan selection switch has 4 speeds. like I said it only works now on high blowing. What can I do
ZACKMAN
  • 4,202 POSTS
Here is a write-up that my have kindly done for you.
https://www.2carpros.com/articles/mitchell1eautorepair-car-repair-manuals
Suggested Repair
Locate the blower motor resistor in the HVAC ductwork under the passenger dash, on the lower right side of the heater housing next to the blower motor. Remove the lower right underpanel silencer/duct, disconnect the resistor wiring, remove the retaining screws, and pull the resistor out; install in reverse. If the fan still runs on high only after resistor replacement, check the blower motor relay. If temperature does not change after the fan speeds work, calibrate the temperature control before replacing the blend-door actuator.
Conversation Summary
Owners of Dodge Stratus vehicles reported the blower working only on high and asked where the blower motor resistor is located. Experts said it is under the passenger dash in the HVAC plenum, next to the blower motor on the lower right side of the heater housing, and gave removal and installation steps. One owner said a dealer had already replaced the resistor, and an expert suggested checking the blower motor relay. Another owner restored all fan speeds by replacing the resistor but still had no temperature control; the expert advised calibrating the temperature control first.
