Transmission Shifting Problems?
ZACKMAN
  • 4,202 POSTS
That would be ATF+4. If there is no code, it must be something that is overlooked. The only two suggestions that I have for you are:
1. Have to make sure that your fluid level is within range. Go more towards FULL than towards LOW on the dipstick.
2. Have someone check your cable linkage. It is possible that it is loose.
Wednesday, August 19th, 2020 AT 8:03 PM (Merged)
AMYLYNN2009
I checked it out, and I seee 2 cables by the gear shifter. I know one is the shift cable, but I'm not sure what the other one is. Which one should I tighten. Thanks for you patience and rapid replies! You are greatly appreciated!
ZACKMAN
  • 4,202 POSTS
Sitting in the driver seat, looking down at the shifter, adjust the cable on the right.
