2005 Dodge Stratus Heater only blows out cold air.
107,000 MILES • 6 CYL • FWD • AUTOMATIC
SERENITY43
My 2005 Dodge Stratus suddenly only started blowing out cold air. I noticed the radiator cap was loose and tightened it. Than my son filled it with water since I did not have any antifreeze. it does have some antifreeze in it though. Once in a while it will start to blow warm air but than it is cold again. It has 107000 miles on it but just replaced the engine and only 40000 miles on the engine.
Nov 15, 2009 at 2:04 PM
MIGHTY PUTTY
I am having the identical problem with my 2003 r/t coupe (3.0) If you find out what it is please contact me on this site my login name is mighty putty
Jan 1, 2010 at 9:32 AM
KEVBAYER
Same problem with a 98 Stratus. Vents don't blow correctly either.
Jan 25, 2010 at 3:12 AM
