2004 Dodge Stratus Water Tank problem
121,333 MILES • 6 CYL • FWD • AUTOMATIC
SVARGAS6
I have to keep pouring antifreeze in the water tank every two to three days due to a leakage, because I do see it on my driveway. The gauge temperature does not get hot while I am driving nor does it smell inside the car. What can be the problem?
Mar 17, 2009 at 10:39 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:c139b4cc71="svargas6"]Engine Cooling problem
2004 Dodge Stratus 6 cyl Front Wheel Drive Automatic 121333 miles
I have to keep pouring antifreeze in the water tank every two to three days due to a leakage, because I do see it on my driveway. The gauge temperature does not get hot while I am driving nor does it smell inside the car. What can be the problem?[/quote:c139b4cc71]
If you are not seeing any signs of leakage on the ground or anywhere then check your oil, is it over full and milky looking? If yes then most likely you have a blown head gasket.
Is there a lot of white smoke/steam coming out your exhaust? If so then once again your most likely have a blown head gasket.
Mar 17, 2009 at 10:45 AM
ZACKMAN
  • 4,202 POSTS
[quote:824a26a89d="svargas6"]Engine Cooling problem
I have to keep pouring antifreeze in the water tank every two to three days due to a leakage, because I do see it on my driveway. The gauge temperature does not get hot while I am driving nor does it smell inside the car. What can be the problem?[/quote:824a26a89d]
If you see puddle of antifreeze under the passenger side every morning, your water pump is leaking. You will need to replace the timing belt as well at the same time.
Mar 17, 2009 at 4:20 PM
SVARGAS6
It's the coolant bottle that I have to keep pouring antifreeze every two to three days. and it leaks as the car is warmed up in the morning. but the teperature gauge does not get hot nor does it smell inside car.
Mar 18, 2009 at 2:41 AM
ZACKMAN
  • 4,202 POSTS
While the coolant reservoir bottle is where you pour the coolant into every 2-3 days, we need to figure out where the leak is coming from. Water pump will leak AFTER the engine is warmed up, and it leaks because of the pressure inside the motor. I still maintain that your water pump is faulty.
Mar 18, 2009 at 4:10 PM
