2005 Dodge Stratus 2005 Dodge Status Won't Start When Engin
PMOKANE
  • 2005 DODGE STRATUS
  • 6 CYL
  • FWD
  • 130,000 MILES
My daughter's will start and run fine in the morning and ater shool, however anytime the car is shut off for only a short period, it will not restart. It then will start just fine after several hours.
When it does not start, the starter clicks like there is a low voltage problem.
Thursday, September 23rd, 2010 AT 12:57 PM
CARADIODOC
  • 33,874 POSTS
Hi pmokane. Welcome to the forum. If that is a single kind of loud clunk each time the ignition switch is turned to "crank", suspect worn solenoid contacts. The problem will get worse over time but for now it will start eventually if she cycles the switch enough times. The contacts can be replaced but most people just replace the entire starter.
If it's a rapid chattering type of clicking, suspect loose or corroded battery cables. A clue will be the head lights or dome lights will go out or get very dim when trying to start the engine. With worn solenoid contacts, the lights will stay bright when trying to crank the engine.
Caradiodoc
Thursday, September 23rd, 2010 AT 1:27 PM
