2002 Dodge Stratus
PALS4EVER2
  • 2002 DODGE STRATUS
2002 Dodge Stratus Front Wheel Drive Automatic
When I try to start my car I need to turn the key back and forth a few times before it will start. It seems to only happen when the car has sat for several hours first.
Friday, September 19th, 2008 AT 9:51 PM
BLACKOP555
  • 10,371 POSTS
You mean on off on off?
Will it not crank unless you do this or just not fire up?
Saturday, September 20th, 2008 AT 8:49 AM
PALS4EVER2
You do not have to turn it all the way off.
But this is the crank.
Thanks
Saturday, September 20th, 2008 AT 3:46 PM
BLACKOP555
  • 10,371 POSTS
Could you please retype that its a bit jumbled!
Saturday, September 20th, 2008 AT 4:36 PM
PALS4EVER2
You do not have to turn the key to the off to get it to start. When you turn the key to the start position
you get a ticking sound if you release it and turn it to the start position about 2-3 times then it will finly trun over and start.
Thanks for your help
Pat.
Sunday, September 21st, 2008 AT 2:00 AM
BLACKOP555
  • 10,371 POSTS
I would deffinetly check out the starter if thats whats happening sounds like the starter is getting the signal, is it a rappid clicking or just one click then nothing?
Check battery also along with the starter relay.
Monday, September 22nd, 2008 AT 9:27 PM
