2001 Dodge Stratus oil leak
2001 DODGE STRATUS
97,000 MILES • 4 CYL • FWD • AUTOMATIC
JOHN CAOXUM
I have a 2001 Dodge Stratus, when i put oil in the vehicle it comes directly back out the bottom, what could this mean?
Jan 14, 2008 at 6:14 AM
  • 31,937 POSTS
Hi there,
Is the sup plug fitted? have you run over something and cracked the sump? It should be easy to see where it is coming from, have a look while someone adds the oil, you should see it leaking if it is as bad as you say it is.
Mark (mhpautos)
Jan 14, 2008 at 6:16 PM
