2006 Dodge Stratus Have a leak
38,000 MILES • 4 CYL • FWD • AUTOMATIC
HYDROGOD
which is more likely to go out first the oil pump seal or the front main seal?
I have a leak and I'm not sure where its coming from but it has to be one of the two.
I've even found oil on the timing belt.
Dec 27, 2007 at 6:13 AM
  • 31,937 POSTS
Hi there,
If you have oil on the timing belt, i would be inspecting the cam seal and the front crank shaft oil seal, as these are the most likely cause of you leak.
Mark (mhpautos)
Dec 27, 2007 at 8:24 AM
